Help understanding props...
  • Alessandro Garabaghi
    • Apr 2016
    • 34
    So pretty new to the rc boat world.
    Picked up the C1 Flowmaster HK Cat
    Setup:
    Neutral Trim
    2x 3300kv
    2x 3s 4000mAh
    2x 60amp esc
    Props:
    Stock: 36x1.4 3blade (39.1mph)
    2nd Set: 36x19 2blade cnc (43.9mph)
    Reading on another forum other people have gotten much faster speeds (~58mph) the the stock setup and 38x1.8 3blade...
    When i do the simple maths of 38x1.8 and 36x1.9 they equal 68.4 (which i believe is the number you look at to see how many mm 1 rotation will push?)
    How come such a difference in speeds?
    What are the main differences with 3 and 2 blade? From real boat world, 3 blades were for top speed, and 4 blades are for low end torque (wakeboard world).
  • Tamelesstgr
    • Jun 2014
    • 1512
    Great prop info in the Sticky section of Prop section:
    http://forums.offshoreelectrics.com/...hp?albumid=991
    My favorites for basic prop understanding:
    http://forums.offshoreelectrics.com/...chmentid=87269
    http://forums.offshoreelectrics.com/...chmentid=87336
    http://forums.offshoreelectrics.com/...chmentid=86485
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
      • Apr 2016
      • 34
      good reads.
      Basically similar to real boat props...
      Now i just need to find a way to get props for cheaper than $20 - $30 each!
      Does anyone make 37-39mm 1.4-1.8p plastic 2 / 3 blades i could test with before dropping a bunch on cnc / metal?
      • NativePaul
        Greased Weasel
        • 2763
        Graupner make good carbon reinforced plastic low lift 1.4 pitch blades around that size, a few 1.6 pitch too.
        • Jamey
          • Apr 2015
          • 199
          An extra 2mm diameter plus 3-blade is pushing more water and is slipping much less than the smaller 2-blade.
