I have an OSE CNC Machined Prop, number 4814. I know the diameter is 48mm, and I calculated the pitch ratio as 1.4 based on the total pitch value (2.65” ~ 67.2mm) provided on OSE (which jives with the model number 48=diameter; 14=pitch ratio (1.4)). I am thinking this would be the equivalent of an Octura x448; is this correct?
Would this prop be considered a high-lift or low-lift prop (Octura bills it as a “general purpose” prop suitable for mono’s and cat’s (maybe other types))?
Here is the reason I ask…
I have a 40” Deep Vee that I converted from glow to FE. I am running a Leopard 4092 930Kv on 10s (2x5s in series - high-voltage, low amp). Prop calculators suggested a 48mm prop, so that’s where I started (using the CNC version so I don’t have to sharpen/balance the prop myself). Note that the stuffing tube exits the bottom of the hull and extends back to an Octura strudder. The strut positions the stuffing tube about ¾” from the bottom of the “vee” (see crude diagram). I do not have trim tabs or a turn fin installed (the boat turns fine; I don’t see any leaning towards one side, etc.). Also note that after about eight minutes of running the boat around half throttle and lower, none of the components are remotely warm and remaining battery capacity is around 35% to 50% (voltage per cell is around 3.75v).
_______hull_________|--------|
........\_________________|_/ |
I can only run the boat at about half throttle – anything more and it starts to chine walk (half throttle is faster as an FE as it was at full throttle on glow (.60)!!!). When I see it go by at this [elevated] speed, it looks like the boat is riding on the prop only, with little to no part of the “vee” in the water. A little slower, and the boat rides like a dream.
I can only mount the batteries to the outside of the hull, as the hull has 5” rails epoxied in place, so moving to the lowest part of the “vee” is out. The batteries are positioned to provide a COG around 30% (measured from the transom). I haven’t fooled around with moving them forward or back as of yet, thinking that maybe a different prop might help.
Question is, which way do I go in prop size? Should I go to a smaller diameter, higher pitch prop (x645), a larger diameter, same pitch prop (x450), or to an “m” prop (whatever those are)? Or do I just buy several sizes/pitches around my current 48mm and just experiment (the props are $20 each, so I’d like to try and make educated guesses here). And what about the whole high-lift vs. low-lift prop – I would think I would want a low lift prop – what are specific low-lift props?
(This last question is a bit off topic from "Prop Talk" but please bear with me)...
Or, should I keep the same prop and try moving the COG back? As it is right now, I think trim tabs might be useless at this speed (with no other changes) as it seems there is little to no hull in the water.
Thanks,
Matt
Thanks,
Matt
