prop size
  • sprintkat
    • Dec 2011
    • 52
    prop size
    got a delta force 33 with a leopard 4092, 1600kv, a hobbywing 180 w/1084 amp capacity using 3s in series (6s) with 4500 mah 65-130c discharge batteries. what would be the best prop to use. an x447 gets everything at 125 degrees at 67mph and an x445 get the temps at 108 degree at 62mph. runtime about 5 minuets b4 checking temps. running boat on a large lake in a wind protected cove, oval racing
  • StevenBryant
    • Nov 2012
    • 359
    Try the M447
      We cannot give accurate recommendations without knowing the motor Kv. How long do you run before checking temperatures? Water temps? What kind of running, oval or high speed zoom zoom back and forth? Little pond or large?
      • FFFCCITW
        • Feb 2016
        • 3
        Try a abc 1915 prop on that boat
