Do these exist or am looking for a ghost? Have twin Leopard 2860's/1690KV w/ twin Aquastar 120 esc's and a 4s battery. It has twin surface drives with 3/16" flex shafts. Am thinking I need smaller pitch and diameter to work properly with this oddball set up. Not really looking for high speed here. Any idea's are appreciated.
Trouble finding smaller 3/16" counter rotating props
Tags: None
Steve here at OSE has Octura X437/3 blade, & 438/2 blade in the CNC range. both with 3/16" bore.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
You can usually run bigger props on motors in a twin set up than you can on the same motor in a single set up in the same size or even slightly larger boat.
Also, a couple of strokes with a file to take half a millimeter off the tips & you are down to a 36mm prop if they are drawing too much load.
But you are only spinning at 25000 revs. Depends on the type & size of boat.
Any pics?See the danger. THEN DO IT ANYWAY!!!
Thanks Jim I am a prop shop dealer but you are probable best off just ordering them from there website http://www.prop-shop.co.uk/index.php?section=homeComment
