HK Relentless V2 Prop
  • Xcessive Carts
    • Sep 2014
    • 99
    One of my boats is a HobbyKing Relentless V1, they have released V2 and it now has a 3 blade metal prop. I have searched and cant find the specs for this 3 blade. Really want to try it on my V1. Any help with this question would be appreciated.
  • martin
    • 2887
    Hobbyking stocks this prop, go to Hobbyking & put in 215000032-0 & you will find it @ $9.02.
    • martin
      • 2887
      By the way this v2 prop is 5mm bore so will be loose on the v1 shaft as its 3/16", just get an Octura 3 blade 37mm diameter x 1.4 prop with 3/16" bore. Which will go straight on the v1 shaft, or you can sleeve the Hobbyking prop to fit.
      • Xcessive Carts
        • Sep 2014
        • 99
        Thanks for all the info, I found the prop you recommended at OSE.
        • Xcessive Carts
          • Sep 2014
          • 99
          The Hobbyking prop is only $9.00, would like to try it and see how the boat runs, before I spend $50 at OSE on a much better version. Now I just have to figure out how to adapt it due to the size difference of the shafts. How do you recommend I sleeve it?
          • martin
            • 2887
            To get by using the Hobbyking 5mm bore prop you can wrap the stock shaft with plumbers tape & then fit the prop.
