Chris ................ email sent ....... all we have to decide is what i need .....
props ...... L @ R
my apologies peoples the struts are not tfl ....... they where purchased from RCBB here in adelaide. you can get them to suit the 3/16 or 1/4 shafts ...... although i run 3/16 flex's these are the 1/4 drive struts and i have drilled them out to fit bearings to support the flex'sComment
well the props are here from Chris ...... i thought it would take a little longer for then to arrive,so i started to do a few alterations to the pads so it will be a couple of weeks before i get to try them out ...... will let you know how it performs with the new props ...Comment
my apologies for no update ........ im now working weekends so my days for playing with the boat/s is limited ..... i took the enzo out a couple of weeks ago and had made a couple of changes to the boat, so i tried the m442 props that i have first ...... well would you believe that the bec *!***!***!***!** itself, so i havent had a chance to try it since ( still waiting for the new bec to arrive) SO ........ im hoping for this wednesday evening ................ will let you know ..Comment
well the last effort to run the enzo ended in tears ............. not exactly tears, but burnt out both servos within seconds of being in the water .......... no water ingress and i cant quite put my finger on the cause, but i think i had way toooooo much tension on the servo's so i could get out all of the slack in the rudder. ...... so im hoping for another try this coming thurs ... (aust ) .... ill let you know what happens this time ........ lolComment
newby error ......... lol ............... i had issues with a mono setup with to much play in the rudder and i was determined that i would not have the same problems with the enzo rudder setup, i was using wire push / pull setup with twin servo's ........ now im using rods with one servo ...... we will see how that goes ...Comment
FINALLY ....... got to run a set of batts through the enzo with out any problems .......... on the last decent run i had and with m442 props ....... we managed 115 kph ......., today ....... with chris's props and a few adjustments ..... 1 ) dropped the struts neg another 1.5 mm .... ( last time it ran was very loose ) and also squared up the edges on the ride pads ........ 113 kph ........ i might have the struts a little too neg ..... ( didnt run loose at speed ) ... next time i go out ill try the m442's again to see what the difference is ....... i only have one pair of 6s batts at this stage, so i dont really get a chance to make changes and run again ..Comment
