Spartan Metal Prop
  • pintobean11
    • Aug 2015
    • 30
    Spartan Metal Prop
    I've done quite a bit of research trying to locate a prop for the spartan I just bought. I'm being pretty picky in the fact that I want a stainless prop with 3 blades. Most everything I'm seeing with Octura, grim racer and the likes really only come in 2 blade. Can someone recommend one that I may be missing?
  • Mxkid261
    • Jun 2015
    • 734
    First off why do you want a 3 blade and second are you running stock electrics? Pretty sure your only 3 blade options are going to be an Octura, an ABC, or a CNC. Im sure someone else will chime in. I had better performance using a 2 blade vs a 3 blade on mine. 3 blade went a few mph faster but cavitated like crazy and ran alot hotter.
    • pintobean11
      • Aug 2015
      • 30
      3 blade is my personal preference. I'm running factory electronics with a larger cooling jacket and the dual pick up system. Temps really shouldn't be an issue.
      • pintobean11
        • Aug 2015
        • 30
        Looking at making a purchase in the swap section. Could anyone help me out on these props?
        maybe the SS prathers 230,235 or the x450 3 blade i would think
        • dasboata
          • Dec 2010
          • 3152
          I have some smaller ABC 3 blades I can do up for the boat PM me if interested thank chris
          • montymike
            • Jul 2012
            • 774
            Factory or smaller check the spartan thread in the rtr section if you want a prop. Dasbota is the guy!
            • pintobean11
              • Aug 2015
              • 30
              bump
              • MR XW 393
                • Jul 2015
                • 2
                Hi, I don't know if you have found a prop yet but I have a Spartan myself, all standard, electonics, flex cable and rudder. I have a balanced and sharpened Prather 215 and that made a significant difference. I could be wrong but I wouldn't go any more on 6s ( I'm assuming your running 6s) and standard running gear. I've been using it regularly for the last two years no problems, good luck.
