Bullet nut on prop wobbles
  • SlickZERO
    • Dec 2013
    • 138
    I had a solid brass bullet prop nut on my Lucas Oil Cat. The stock Aquacraft ESC seemed to start suddenly at about 1/4 throttle no matter what I did. I just replace it with a HW/Turnigy 120A ESC. When running it slow to check direction I notice bad run out with the prop nut. The point of the bullet nut was going in a circle about 1/8" in diameter. Looks like the hole/threads are at an angle. Replaced it and the buzzing sound vibration was gone. I had put it on when I got the boat so thought the vibration was "normal". Check your prop nuts.
    Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33
