What prop for my setup on 3s?
  • boilo56
    • Aug 2014
    • 390
    Originally posted by martin
    The stock prop has a low blade area ( detongued & backcut ) also with a low pitch. It is a 43mm diameter x 1.2 pitch ratio = 51.6mm pitch or 2.03" pitch, as a comparison an x442 is 42mm diameter with a 1.4 pitch ratio = 58.8mm pitch or 2.31" pitch which will also have less slip with the extra blade area as well as more pitch for higher speed over the stock prop.
    I know it is not the best prop, but still, it is a good prop for learning and sport running. I got 69 kph today, on this prop. i was running 4s 5000mah 40c and 2200kv motor on the t180a. It is a gentle prop for the electronic, less heat! But again, i'm not running that prop often, i usually run x442 and x440/3.
    • martin
      • 2887
      Yes they fit this prop to help the motor & electronics as its a low amp draw prop, bearing in mind the stock 3660 motor is not that powerfull in a 32" mono & better suited to a 40 size motor.
