3 blades prop, how can i calculate the speed?
  • boilo56
    • Aug 2014
    • 390
    I would like to know how to calculate the speed on three blades props. The OSE Speed calc doesn't give the option. Is there a multiplying factor to be used on the two blade results to get the 3 blades prop speed?
    thank you!
  • dasboata
    • Dec 2010
    • 3152
    Theoretical speed,,,,, in a solid surface which water is not , rpm X pitch - 15% threw 35% or so slip,,, a 3 blade will have less slip
    • boilo56
      • Aug 2014
      • 390
      Thank you, so a 3 blades prop slips 15% to 20% less than a 2 blades, am i right?
      • dasboata
        • Dec 2010
        • 3152
        I don't have any figures to me slip is a good thing it lets you spin larger blades my rule is 3 blades on a mono to help handling & 2 blades on a cat for top speed ,, but this is not always true,, Keith K. like to run 3 blades on his cat and he has record breaking boats
        • boilo56
          • Aug 2014
          • 390
          I guess it is to the pilot liking then!
          • Luck as a Constant
            Make Total Destroy
            • Mar 2014
            • 1952
            Forget calculating speed and try the prop. Then gps it with prop.
            • boilo56
              • Aug 2014
              • 390
              That is exactly what i did!http://forums.offshoreelectrics.com/...t-)#post630457
              • Meniscus
                Refuse the box exists!
                • Jul 2008
                • 3222
                It is important to remember to be careful when you go from 2-blades to 3-blades. The amp draw increases which, in turn, means that the voltage may sag more in addition to the possibility of more heat or stress on a given ESC. Although it may be great theory that a 3-blade will slip less, it doesn't mean that it will equate to a faster speed. In my experience, I often use a 3-blade prop when I need to keep the transom up. You are able to do this with a 2-blade prop as well, but everything depends on what the model likes.
                Regardless, please be sure to take into account that many 3-blade props have higher pitch (or a different progressive pitch) which means that you would need to go down in diameter. It's needless to say, but always try a prop with less diameter when going to a 3-blade and measure temps closely on short runs before you increase the diameter.
                Another aspect that is not addressed here is the condition where you may have loading and unloading of the prop if the prop lifts out of the water for any reason (rough water, wake, skipping, etc.). These swings in current and load may be exaggerated on a 3-blade prop and may ultimately become detrimental to your ESC. Happy testing!
                • boilo56
                  • Aug 2014
                  • 390
                  Hi Meniscus, i noticed the increased amp draw, as my runtime on 3-blades as shorten by almost 30%.And i did noticed an increase in temps also. My batteries are the one thing that suffer the most, the temps were s bit high after the run on the x442/3.
                  • martin
                    • 2869
                    If going from a 2 blade to a 3 blade I generally reduce the prop size by around 10%, ie if im using an x442 2 blade which is 42mm diam x 2.31" pitch. If I go to a 3 blade I will use x438 3 blade which is 38mm diam x 2.09" pitch, theirs a lot more blade area on the 3 blades to push the amps much higher.
                    • boilo56
                      • Aug 2014
                      • 390
                      How can i know the amp draw without logging?
                      • martin
                        • 2869
                        You cant know without logging, one thing for shore if you go from a given size 2 blade to a 3 blade of the same size you will see an amp draw increase just because of the extra blade & increased blade area.
                        • boilo56
                          • Aug 2014
                          • 390
                          Ok, thanks, i'll keep this in mind! Sounds like a good habit!
                          • TRUCKPULL
                            • 2971
                            There is one way to calculate AMP draw.
                            But this is average Amp draw over time.
                            Lets say you put your boat in the water and run an oval coarse for 2:00 minutes,
                            when you recharge your batteries you put 4,000 mAmp's back in the pack.
                            This calculates out to 120 AMP's average draw.
                            Remember that when running an oval the Amp draw will be a little higher pulling out of the turns,
                            and a little less the second half of the straight away.
                            Print the chart below and keep it for your records.
                            Larry
                            • boilo56
                              • Aug 2014
                              • 390
                              Thank you very much, this chart will be very useful!!!
