I just got my blackjack 29 inch I put a leopard 4074 2000kv 4 pole with a seeking 180 amp electric speed controller running 6s which prop would be recommended for best speed with This build which mm etc
Just put my blackjack29 leopard engine need help with prop size
Tags: None
Don't know why you want to run 6s with a 2000kv motor but I'm thinking an x440/x442NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I agree! here is what I typed two days ago but didn't post because I thought I was being too long winded:
Is this a new boat? why don't you run the stock set up till you are more familiar with the boat?
Not saying that it can't be done, but to start on 6s with 2000kv, you should expect to start with a prop on the small side like a 440, certainly no bigger than 42mm, IMO.
I have never run anything from 2000kv on with 6s, 5s was the most I did. I like to have a margin of comfort for myself. You are asking quite a bit from your components. People who know how to tune their boats do it, but whether it is a success or failure has so much to do with tuning and having a wide disposition of props at hand and knowing how to adjust the strut.Too many boats, not enough time...Comment
Just so I can know why wouldn't u run a 6s on a 2000kv motor ? After which kv till which kv motor u recommend a 6s I've had tv boats before but always left it stock it gained a few mph after I did the swap and adjusted the strutComment
What's going on here
Alexito da barber
And
Alexbarber
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
For 6s 1400-1600 is good
Thanks bud any one know the shaft size of the black jack 39 how do I search for a x440 x442 online which will fit my boat I dont wanna order one then it doesn't fit on the shaft, thanks againComment
3/16, you need to get balanced/sharpened props, not the raw ones. I cant see on my phone if they are instock or not.
Dasboata (Chris Hoffman) isba great guy to ask for props service. You can PM him as well.
Sent from my D6708 using TapatalkToo many boats, not enough time...Comment
