props????
  • luv2fly27
    • Feb 2015
    • 30
    Blackjack 29 v3 props
    any suggestions for the best prop for the new blackjack 29 v3? Looking to run on 6s. From what I've read an Octura x442 S&B seems to be the best bet?? Any others to get top speed?
    • Make-a-Wake
      FE Rules!
      • 5557
      If its the 2000kv motor i think 6s is overboard................if you want to run that though a 442 is too much prop, x438 or possibly x440.
      As a friendly reminder to a new member, in the future its best to start your own thread with a question about your own boat which is completely different from the OP's twin larger Cat.
      • luv2fly27
        • Feb 2015
        • 30
        Ok thanks! Yes it is the 2000 kv motor. I tried 4s out of the box and it wasn't very fast thus went 6s which was much more fun. My motor and ESC are barely warm to the touch after running for 7-9 minutes. Was just looking for an easy upgrade to gain even more speee in a super flat pond I use. Sounds like I should try the x438 or x440. Any preferences? Thanks Again and sorry for not starting a new thread I'm new to the site :)
        • Make-a-Wake
          FE Rules!
          • 5557
          You can start with a Graupner K series in the 38-40mm range for testing, 6 bucks each, then move to a permanent prop like the Octura
          • luv2fly27
            • Feb 2015
            • 30
            Do you think I will notice an increase in top speed with the upgraded prop as compared to the stock prop? If it's 2-3 mph im guessing it's not really worth it. If 5-10mph I'll probably spend the money. Thanks!
            • RCBoaterGuy
              • Dec 2014
              • 213
              Here's an excellent thread for the new BJ29v3's... http://forums.offshoreelectrics.com/...C5-plugs/page2 - might wanna follow make-a-wake's advice & post your questions there. That'll give you the opportunity to share the results of your tests for the benefit of all, just as others have.
              AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
              Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
              Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
