Prop installation question
  • SirBudman32
    • Aug 2011
    • 625
    #31
    Yes the collet need to be Tight. As I had told you before, if that prop L40x57 is Not SHARP and Balanced it will NOT work. Have you messed with the settings one the strut or turn fin at all? Take the prop off and set the boat on a flat surface so the strut and ride pads are the only thing touching, while leaving the turn fin hang over the edge. Set the bend of the turn fin level with the surface of table or what ever you have it setting on. Now set the strut level and at 1" to 1"and 1/16th on a inch from the surface of table to the bottom of the boat. Here is a video of mine running a 42x55 prop, runs 45 all day long.
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
    • tlandauer
      • 5666
      #32
      Nice Video!!
      • tlandauer
        • 5666
        #33
        If I may say, it is NOT uncommon to have problem with the stock Aqua Craft collet, if I were you I will change to an Octura one ASAP, same thing with the flex cable, don't wait until you have a nice working prop and then something goes wrong and you lose that prop.
        This one: http://www.offshoreelectrics.com/pro...ct-ocfhe5mm15S
        or
        This one: http://www.offshoreelectrics.com/pro...ct-ocfhe5mm15d
        and finally: http://www.offshoreelectrics.com/pro...=ose-cable-ul1
        • djviko44
          • Nov 2014
          • 26
          #34
          Thanks for the tips guys! i will try to setup the strut as you said sirBudman and thanks for the tip tlandauer but i believe i can't buy stuff from OSE cause they don't deliver to Mexico ;-(
          Ill try to buy it elsewhere (is the flex cable also from Octura? do you have a part number?)
          thanks a lot!!
          • tlandauer
            • 5666
            #35
            thanks a lot!!
            I actually don't know, but it is a .150 cable with a 3/16 shaft.
            You can buy them and cut the cable to the proper length using a cut off wheel with Dremel rotary power tools.
            • djviko44
              • Nov 2014
              • 26
              #36
              SirBudman, regarding to the adjustments on the shaft of my boat... is this what you meant? thanks a lot!
              • SirBudman32
                • Aug 2011
                • 625
                #37
                yes.
                • djviko44
                  • Nov 2014
                  • 26
                  #38
                  so i guess it's correctly setup now... thanks a lot! i already sharpened my prop more, hope to see better results tomorrow
                  thanks a lot to you all
                  vic.
                  • SirBudman32
                    • Aug 2011
                    • 625
                    #39
                    give her hell
