Larger dia. or more pitch
  • Daveknitter
    • Dec 2013
    • 42
    Considering making prop change not sure what to go after first larger dia. or more pitch. current set-up 40"deep vee, Leopard 5692-730kv,
    Hydra Ice 2 12-cell 50 volt max, running 2-5 cells in series, X455 prop, runs middle 50s mph, every thing comes in barely warm. Is it a coin toss or rather just a lot of trial and error to either go for larger dia. or more pitch keeping in mind watching boat temps, if i'm looking for more speed. Which one should i go after first?
    I would try more pitch first if they offer the same prop you have now with more pitch.
    • properchopper
      rcgoatbuild@snotmail.com
      • 6968
      Large heavy monos won't benefit from increasing the pitch as in your situation. You need more diameter so step up a notch.
      • kevinpratt823
        • Aug 2012
        • 1361
        Or try a 455-3 blade.
        Sent from my SCH-I535 using Tapatalk 2
        My private off road rc track
        https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
        • Rocstar
          Joel Mertz
          • Jun 2012
          • 1509
          Agreed. Try a larger wheel first.
          • properchopper
            • 6968
            Good call - mo'better acceleration that way as well
            • Make-a-Wake
              FE Rules!
              • 5557
              I'd try a Prather s240. 53.8 diameter and they are 1.5 ptch.Total pitch is 3.3 and your x455 is 3.0. should pick up at least 5-8 mph
