Guys, how far can the shaft extend from the strut past the strut? Using a speedmaster setup and hughey 3:16 flex shaft. This is for a neu 1527 setup on 6s. My prop is just at the edge of the transom and I need to know if I'm ok to just make the shaft extend longer or if I need an extended strut (its a center mount/under setup). Thanks
Distance prop/drive dog from strut on 3:16 flex shaft
Mount the strut , install the drive dog on the shaft , put the shaft in the stuffing box up into the collect measure the distance between the back of the drive dog and the face of the strut , leave yourself 1/8 play between the back or drive dog and the face of the strut,, as the shaft shrinks under loadComment
Just set everything up and somewhere between 1/8 and 3/16 gets me where I need to be - thanks! Das I'll be in touch for a prop.Comment
Jhl1963.
The rules here in Aussie land for 1/8 scale hydros is that the drive dog shall not extend past the transom. I assume that the same applies over there in the States. That's why the strut is mounted under the boat & not behind the transom like a Sports Hydro. The prop shouldn't hit the transom if you have the strut depth set up correctly.
Here's one of mine temporarily set up.
Someone let me know if the rules are different over there please. Just interested, that's all.Attached FilesSee the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
OOPs. My mistake. I thought, for some reason, that it was a 'scale' setup. Not a 'Sport' setup. I should learn to read properly.See the danger. THEN DO IT ANYWAY!!!
