This is a nice order I did last week 6 sets of X470 cut down to different diameters thinned and hardened and a bunch of other props 28 in all B/S thinned these are on the way to a SAW event !
props before and after harding
I have a few questions if you don't mind as I work (try) on my own props.
How do you cut the diameter down what do you use?
Do you anneal then rework and then harden?
Most people will never do all this work but I will.....maybe some day I own a boat that needs harden props. Ha I am sure it holds a sharp edge longer than normal.
Best,
MikeDo It Like You Mean It .....or Don't BotherComment
Thank you, as it seems you are doing it right. In the future would it be of interest to you if I were to ship some props for you to harden? As I do not have the right oven, bath for this heat range, time. And I very much agree with heat treating is not always needed. It would only be for those I have changed pitch/rake. I would assume to pay for your effort and time.Comment
Pitch is how much the prop will move forward, rake is the slant of the blades. A lot of people just say pitch. I more so twist the blade while bending so it's not technically changing the rake as I'm not removing the blade from hub. Sorry about that terminology, either way the blades are bent/moved from their original castings and I like to run high rpm so re-hardening is beneficial.Comment
MORE GUYS!
I found this in papers I down loaded last year while I was cleaning up my basement work shop. If I could have figured out how to attach a word doc. I would have so everyone could read easy. Here are the address's
http://materion.com/...eryllium Parts
Bottom one is heat treating and I put it on IW's too.Do It Like You Mean It .....or Don't BotherComment
