fastest way to thin props...
  • Chris Harris
    • Oct 2007
    • 182
    One important piece of equipment to remember is a respirator or at the least a really good dust mask.
    This is especially so when using power tools to remove material from beryllium props. Beryllium is very bad stuff
    to be breathing in, so take precautions even when using a vacuum, although it helps, it will not collect all the dust.
    My .02
    Chris
    I.M.P.B.A. Record Holder P-Hydro 111.001mph Q-Hydro 120.192mph S-Hydro 139.233mph
    • kingwrench
      • Sep 2011
      • 193
      I have all the tools, belt sander, buffers, rouge, rotary tools, balancer, pitch gauge,brass hammers and pitch blocks. But with age comes wisdom I send all my props to Chris, dasboata. Great job, and my fingers don't get dirty..
      Top Gun 2011, "current problem" 88MPH. Top Gun 2014 "Marine One" 99 MPH. bet speed to date 125 MPH
      • Cooper
        • Jan 2011
        • 1137
        The thing to know about beryllium exposure is OSHA max limit is 25micg per cubic meter of air not ever to be exceeded. That relates to a 16gram prop with 2%beryllium removing about 2%of the prop while working ending with about 400micrograms. Open a window a have a fan on. That would be more than adequate for the 2microgram per 8 hour shift with a dust mask on that OSHA equates safety standard to.
        • Wetter
          • Aug 2013
          • 241
          why do they use beryllium then?
          here in California i am surprised they haven't caught on, hell they want you to hold your breath so yo don't exhale carbon monoxide
          it's funny how all the bad stuff is better at what it's suppose to do like freon, asbestos, chlordane and my cookies.
          • detox
            • Jun 2008
            • 2310
            Some smaller props are cast thinner than others which makes them easier to thin. The m445 is a thin cast and a verygood prop to cut, bend and learn on. You can cut diameter down if too large. The x442 is also pretty thin. Usually larger props are easier to work on.
