hub inbalance
  • iop65
    • Mar 2013
    • 367
    hub inbalance
    I have a grimracer 42x55
    when i started balancing it was obvious that one blade was heavier then the other,but now it always stops horizontaly when i spin the prop
    it's always the same side thats underneat
    so the hub is heavier on one side?
    and if so ,what to do ?
    there's also a lot of movement possible when i put this prop on the axle (nut not tightend) or the balancing shaft
    the stock prop ( impulse 31) fits without any possible movement like you would expect
  • Doug Smock
    Moderator
    • 5272
    You need to remove material from the leading edge of the blade that is hanging below the axis, and the trailing edge of the blade that is hanging below the axis.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • iop65
      • Mar 2013
      • 367
      thanks going to try that
      but is it normal that it fits so slopy on the axle/dog-drive? and the balancer shaft?
      like i said , the stock one and the cnc-prop i bought ;they fit without any possible movement!
      i'm rather new in metal props ( always used graupner carbon props)
      • NativePaul
        Greased Weasel
        • 2761
        I've not used a Grimracer or ABC prop yet, only Octura, Prather, Propshop and Tenshock, but all mine have been a good fit on the stub shaft.
        I put some calipers on my stub shaft and if that is the right size still I would send the prop back, no point in putting effort into balancing it when it will want to throw itself into the most out of balanced position it can when it is lose on the stub.
        • iop65
          • Mar 2013
          • 367
          i stopped working on it;it will never fit properly
          a case of bad luck i think,it was just a bad casting ( had to fill an air bubble in the hub to)
          will cost me more to send it back then its worth ( live in europe)
          • NativePaul
            Greased Weasel
            • 2761
            I think Grimracer are pretty good for customer service if you send them a photo of the issue and tell them how much it is to send it back they may replace it without you sending the duff one in.
            look into the postal cost I sent a prop from here in England to Butahn in a tiny box I made to suit, and it cost less than £3
            • NativePaul
              Greased Weasel
              • 2761
