Ok I have gotten back into the boat scene and need some help. I picked up a wildcat ep , just a good simple brushless boat . I need to know what a good metal prop would be for it.
prop help for wildcat ep
Tags: None
i have looked myself as i too started with a wildcat... the ID of the prop itself is smaller than most prop flex cables. I too want help!! -
Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
That is the dia. 42mm, isn't it? So any 1.4 pitch metal prop that is 42mm will do, I would be cautious since the metal prop is heavier and check your temp. if I were you I would get a x440 first, then increase to 42mm like x442, but that is a very expensive way to up grade. http://www.offshoreelectrics.com/pro...rod=octsb-x440, http://www.offshoreelectrics.com/pro...rod=octsb-x442
You may also look at some of the CNC props: they are less expensive, I have no direct experience with them: http://www.offshoreelectrics.com/pro...+2+Blade+Props
The other thing ---as you may know already, the stock shaft is not 3/16" as with most metal props , what is the size? if it is 1/8'', then you need to use this:http://www.offshoreelectrics.com/pro...?prod=ose-1035, since most prop use 3/16" shafts.
In my opinion, since the boat is light, the stock prop will not flex that much under power, the improvement you expect from a metal prop may not be that evident.
I have a Rio EP converted to a brushless using the same plastic prop, here is the link:http://www.youtube.com/watch?v=iCSzhyfHF3w , I did not change to metal prop, I still like the performance.
Just my $.02
Cheers!Too many boats, not enough time...Comment
