Any suggestions for prop for 22.5 mono running 2860 3400kv, 120a ESC. I tried running on 3s but i think it was to much. I am going to try it on a 2s. Looking for prop suggestions. Thanks!
Prop Suggestions - 22.5 Mono
On 2s I'm thinking an x440/x442...........possibly even an x637NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Is the mono you are talking about the R2 Hobbies Arowana? If it is I have one ( wife's boat ) It has a 2223 2900 out runner running on 3s 2200 batteries and running a 35mm prop doing 25-30.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
I have a wire drive in mine with a 1/8 inch prop shaft and run both 32 and 35 mm props on it and it flies for a little boat. Just can't get it to self right it's self.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
where do you have your strut set? mine is level with bottom of the hull and I put on a set of trim taps. Runs real dry and flat.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
Here is a small video of wife running hers with me and my Sv27
No, always runs smoothModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
I have everything but the rec. on the port side.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
