Revolt 30 how too hit 70mph
  • RandomHero
    • Jul 2012
    • 88
    OK I have a revolt 30 with a 4082 an a seaking 180A esc i run 4s and 6s what prop will put me around 70mph so i can run with my bass boat im runing a grim racer 42-66 now and its not quit there thanks for the help if u can
  • RandomHero
    • Jul 2012
    • 88
    2200kv sorry
    • dana
      Banned
      • Mar 2010
      • 3573
      I would think an x642 would get you close, but you're running on thin ice with your setup.
      • dana
        Banned
        • Mar 2010
        • 3573
        Also, you better reinforce the hull. A wipeout at those speeds could be catastrophic
        • RandomHero
          • Jul 2012
          • 88
          its reinforce with steal and foom and how would u get it off thin ice what do i need
          • G-UNIT
            • 949
            Is'ent a 2200kv motor only good for 4s. @ 5S your pushing 40.700 rpms boom goes the motor?
            A 1200kv - 1600kv motor would handle 6s.
            look for the voltage chart in here some where.
            • Make-a-Wake
              FE Rules!
              • 5557
              That hull wont be stable at 70.................looking for trouble.
              • dana
                Banned
                • Mar 2010
                • 3573
                I agree, the revolt is limited by hull design, not power. 70 mph is just not gonna happen with any good results with this hull. Also 6s on 2200kv Leo won't last long. You might be able to do this with a better quality motor such as Neu but even then you should limit run times.
                • RandomHero
                  • Jul 2012
                  • 88
                  it saying 22v max
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    What you need is a hull capable of 70 mph. Then an appropriate motor/ prop combo. There are several combos that could do it, but you need to decide what's within your budget....
                    • RandomHero
                      • Jul 2012
                      • 88
                      so stay with 4s gotcha what speeds am i looking at with the biggest prop?
                      • dana
                        Banned
                        • Mar 2010
                        • 3573
                        Originally posted by RandomHero
                        it saying 22v max
                        Yes, that doesn't mean that running the full 22 is recommended. Keep in mind that you're going direct drive. In a Rc car where the motor is geared down, 22 V might be ok, but not so much in a boat.
                        • RandomHero
                          • Jul 2012
                          • 88
                          money not a problem
                          • dana
                            Banned
                            • Mar 2010
                            • 3573
                            Well with an m445 or x642 you may get between 50-60mph...
                            • RandomHero
                              • Jul 2012
                              • 88
                              ok i see thanks
