Hi guys
someone of you twinbuild speedfreaks know wich size prop i need for my zonda cat?
Informations about the Boat:
Length: 41" or 1050mm (excludes rudder and strut)
Width: 11 3/4" or 300mm
Motor: 2 unit x water cooled 2075KV 3674 brush-less in-runner with motor mount (no idea of the name, think is one of the TP)
Esc: 2x Swordfish 200Amps PLUS Esc. (connected them with y plug into channel 2 of the receiver, one esc is without bec cable)
Lipos: 2x 5s (one for each motor) 5000 Mah 40/80C.
Drive system: stainless steel collets, 3/16" flexi cable, brass tube, teflon lining, teflon washers, prop nut, drive dog (installed) Other accessories: antenna mount, water tubings, rudder, stinger drive
Radio: Spektrum DX2
Servo: Traxxas 2056 Servo
Both Esc´s set on:
LVC: 5 Cells
Cutoff Voltage/Cell: 2.8V
Brake Type: no brake
Timing Adance: middle
Cutoff Type: hard cutoff
Startup Type: standart
PWM Rate: 8 Khz
(optional) Trottle Range: coming if i set the throttle on the radio and receivar with failsave.
because i have no idea what size props are coming with it (getting it in the next 2 weeks i hope) i need some informations or ideas of you what i shoud mount on it for max speed and no overheating problems.
by the way, if i set the ESC´s wrong just tell me, 1st try in twincats :-(
and sorry for my english, coming from Austria, its not the yellow of the egg.
Radio: Spektrum DX2
Both Esc´s set on:
LVC: 5 Cells
PWM Rate: 8 Khz
