Prop Suggestion!
  • SirBudman32
    • Aug 2011
    • 625
    Prop Suggestion!
    Took my Genesis out today after rebuilding motor and new batteries, just don't seem to be get the rpm's like it should.
    I'm running a CC 1515 2200, T 180, On 5s 5000 40c batteries. Tried with a M440 3 blade not bad but still should be more, Tried a X642, boat seem to run better but esc did not like it, 145f after 2 minutes and went into thermo shut down. looking for suggestion on a prop to try. Thanks for any Ideas.
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
  • masonis1
    If you cant control it 👍👍
    • 1173
    i have a mg. i know lots of people say octura x series are good. i run a grim 42*55 and its decent. everything stays cool.
    x442 might be a good try
    Sent from my SPH-D700 using Tapatalk 2
    • Make-a-Wake
      FE Rules!
      • 5557
      m445
      • SirBudman32
        • Aug 2011
        • 625
        Thanks for the tips. Which way should I go, smaller diameter same pitch, or same diameter less pitch to get more revs out of the motor? looking into the x442 the m445 and the x438.
        • Heaving Earth
          Banned
          • Jun 2012
          • 1877
          i run neu 2200kv on 5s in my mean machine with seaking 180 and m440 prop. 56mph heres a vid http://www.youtube.com/watch?v=TDUyJfai9-Q
          • Heaving Earth
            Banned
            • Jun 2012
            • 1877
            and yes it will go into thermal shutdown if its really hot out or i run for over 4 minutes. just the nature of electrics man. its what happens when you push it
            • Make-a-Wake
              FE Rules!
              • 5557
              My bad on the m445, I assumed you wer running it on the stanf=dard 4s fir a 1515 2200kv, now my suggestion is an x440
                • 7673
                I would also stay with a 442 or 440 with 5s in these summer months.I have been running my Geico with a CC1515 and T180 for a year now.I was running a M645 but am down to a X642 now that it is warming up.
                • CHIEFY_44
                  • Nov 2010
                  • 254
                  You could also try turning the timing down and run a m445/545 reduced timing will help with heat you may lose 1 or 2 mph but lose a lot of heat build up, which is not good for the motor,esc and your cells, I have a mg that I run a leopard 4074 a t-180 with a m445 on 4s2p never had any heat or speed problems and it runs at 55mph regularly. Also I try not to run at half throttle as this can generate heat in the esc. Just my 2 cents worth.
                  Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
                  • highflyerbill
                    • Jul 2011
                    • 152
                    I've been running a MM now for 7mos. with a lep 4074-2200kv 5000 mah 4s2p with a x442 I've set the timing at 3.75 on my t-180 and it runs very well no heat issues . Even on a 100deg. day it ran better then I did . Even when I ran nitro boats you had to back off on the needle setting on really hot days . This weather is good for the grape vines not so good for FE's
                    • martin
                      • 2887
                      The Leopard 4074 - 2200kv is a y wind motor & is better suited to 10 - 15 degrees, 3.75 degrees is for d wind motors.
                      • highflyerbill
                        • Jul 2011
                        • 152
                        On hot summer days every thing is much happier when runner on the Conservative side . Don't you agree ??
                        • martin
                          • 2887
                          No a y wind motor is not running efficently on low timing. Low timing is not conservative on a y wind motor, the same as a d wind motor wont run efficently on higher timing. Timing numbers dont mean the lower the number the more conservative it is as it all depends on the wind.
                          • highflyerbill
                            • Jul 2011
                            • 152
                            that statment is just not correct . Do you know what effect timing has on a motor?
                            • martin
                              • 2887
                              What your saying is that the timing number is the same for d wind & y wind motors, is that correct.
