The time has come were I need to buy the right props for the job?
looking for some advise
this is the setup.
twin Rivercat running 2 FC x 3126 1600KV motors
2 x long 450mm 2mm wire drives conected to 4mm threaded 70mm stubs, i also have 4mm/ 3/16 converters I could use if needed,
can any one tell me what props I would need, and how the right hand prop will stay on without winding of, do i bond the prop to the shaft on one side to stop it spinning of the shaft?
looking at 2 x 45mm props counta rotating? or can I use two standard left hand props and bond oneside on the shaft to stop it spinning of
both the stubs have the threads going the same way. do i need one with a revers thread?
hope this all makes sence.
this is the setup.
