prop question
  • camarohrod
    • Mar 2012
    • 64
    prop question
    is i was running too small of a prop would it make my esc run hot? my motor and batts r fine but the esc is getting hot. im new to the boat scene and dont really know much about this yet.
  • ejimbo4
    • Jul 2011
    • 189
    Don't know much myself but more info is definitely needed .....motor size(kv),type of esc, type of batteries,prop size,type of hull and hull length?
    Everything I do I learn something new!
    • electric
      • May 2008
      • 1744
      Just the opposite. More prop equals more amps equal more heat. Other things that heat up an esc are running a lot at partial throttle or short runs like in a small pond.
      • electric
        • May 2008
        • 1744
        And excessively long run times
        • camarohrod
          • Mar 2012
          • 64
          its a skywing sw150a esc, 4s 20c 4000mah lipos, 40" genesis, no clue what the prop size is or what the motor is, here is a pic of each if it helps any. theres plenty of water coming out of the side of the boat so i know its getting plenty of flow.
          • h2o 1
            • Sep 2011
            • 770
            The motor is a stock Genesis 36/74 2075kv.
            • lenny
              • Sep 2010
              • 4294
              Have any pictures of the insides of the cat set up and wires ?
              And take the prop off and look for numbers and check that the flex shaft is free.
              ? ONLY IF THEY WORK
              • camarohrod
                • Mar 2012
                • 64
                ok prop is a 435, the shaft may have had a bit of a bind in it so i loosened the motor and gave it more of a strait on shot and greased the shaft.
                • lenny
                  • Sep 2010
                  • 4294
                  The shaft should turn with two fingers smoothly in open coupler on motor.
                  That is a small prop for that boat,
                  Need to see wire connector, No pictures yet ?
                  If that is a stock motor, I think they pull high amps and are not very good.
                  ? ONLY IF THEY WORK
                  • h2o 1
                    • Sep 2011
                    • 770
                    I would also go to a higher c rated batts.
                    • camarohrod
                      • Mar 2012
                      • 64
                      well still the same problem, it starts falling off really quick on power and the esc is still hot, here is a pic of the whole setup but i have the boat in pieces right now. i run the 4s batts in parrelell also.
                      • camarohrod
                        • Mar 2012
                        • 64
                        the shaft seems to turn really easily so i dont think thats my problem
                        • lenny
                          • Sep 2010
                          • 4294
                          I do not like the deans and to much different wire sizing going on to.
                          Go with 5.5 bullets all the way.
                          The esc is getting hot when running the boat in the water for how long and how hot.
                          ? ONLY IF THEY WORK
                          • lenny
                            • Sep 2010
                            • 4294
                            You also need to have a 3/16 gap for your flex shaft from the back of the strut to the prop dog.
                            And take the wight washer off, You do not need it.
                            ? ONLY IF THEY WORK
                            • camarohrod
                              • Mar 2012
                              • 64
                              i have a good gap between the prop dog and strut, your goin to think im crazy but it gets up to 180+ after about 5 minutes of running, and ive done that read three times. what size wire do you sugest i use all the way? the batteries have 12awg coming out of them.
