Hi
I need a little help here guys as im not sure if this is a prop selection question or not
I have an R2 Godspeed cat running the following
Leopard 4074 2200KV motor
turnigy 180AMP esc
3/16 driveline
runs on 4S, 2*2S 40C 5000mah zippy batteries
i have a X440(3) that works very well with this setup low temps on all hardware, but i have previously run the same setup with an X445 in a rigger and very low temps, just recently i got a X445 and an M545 to test on my hull but when it came down to exiting a corner with both of these props the esc cut the power to come in. so i guess im asking if i am over proping the setup, the other thing i need to mention in my static balancing the props seem fine but when on the test bench the seem to be a small vibration with both of my new props but not with the 3 blade.
the temps could not be measured properly as i only get a few laps before it cut out on me with the new props
can someone please shed some light as to what is going on
video here of the 3 blade
turnigy 180AMP esc
3/16 driveline
