Need P-Mono Pursuit 4082 2180KV Prop Advice
  • Bullwink
    • Oct 2011
    • 244
    Hi all,
    I am new to racing and am competing in the Winter Warmups here in Scottsdale today and tomorrow. I am running a Pursuit with a TP4082 2180KV with a SeaKing 180Amp ESC. I was running a S/B Prather 230 until I lost it and the prop shaft in a crash with another boat. The motor temp was never above 112 and the ESC was 90. So I think I can prop up, but is that best? Here are the props I have available to put on for the races tomorrow: M447 , X645, M645, and a X450. Any suggestions? I am running 40C 4S2P 5,000MAH. (10,000 total MAH)
  • Diesel6401
    Memento Vivere
    • 4204
    Originally posted by Bullwink
    Hi all,
    I ran a m645 on my Pursuit with a Leopard 4074 2200kv. It was working the system pretty hard but was darn fast. You have larger rotor and more amps available from the batts. Shouldn't have any problems spinning that m645 especially if you spun a s230 without any issues. A 225 might not be a bad fit either. Jmho
    - Diesel's Youtube
    - Diesel's Fleet
    • Bullwink
      • Oct 2011
      • 244
      Thanks Diesel!
      • Chilli
        • Jan 2008
        • 3070
        Be carefull. The motor might like that prop but the Seaking 180 might have something to say about it. If you're new to racing, go conservative with the prop, learn how to run the buoys and in traffic. You'll soon learn the fastest boat doesn not always win the heat.
        Have Fun and let us know how things worked out for you!
        Mike Chirillo
        www.capitolrcmodelboats.com
        • Bullwink
          • Oct 2011
          • 244
          Chilli, thanks for your input. Driving around buoys, in traffic, with a lot of chop, has been a huge learning experience for me! We have really tight turns without much room here so, I learned to slow down going through the turns, and try to hold my lane. That being said, this is were I get confused about props. If the Prather 230 has a total pitch of 3.0" and a M645 has a total pitch of 2.832, wouldn't I be propping down with the M645?
          • Make-a-Wake
            FE Rules!
            • 5557
            I run a 4082 in my pursuit with a 200a Swordfish for some extra "room".................i spin an m445 for low 50's on speed.................but i'm also running 2p, the 4082 can draw some big amps.
            • Chilli
              • Jan 2008
              • 3070
              Blade shape also is a big factor in determining load on you equipment. I've never used Prather props but I know ABC props that have the same numbers as an Octura put much more load on the motor. I don't have personal experience with your motor and thats why I didnt recommend a specific prop.
              My suggestion was just a general statement I tell all new racers. Many times I've seen new guys more worried about having the fastest boat rather than learning how to race. Looks like you have experience running the course and in traffic so thats great. I suggested you go conservative on the prop because race day can be a bad time to experiment. I don't want you to burn anything up because racing isnt fun if your sitting on the sidelines. Plus there is a chance a different style of prop is going to mess up your boat handling which will require a change in set up. The faster you go, the worst the problem can be.
              Good Luck!!
              Mike Chirillo
              • Bullwink
                • Oct 2011
                • 244
                I totally agree with everyhting you say. The last thing I want to do is fry my ESC and not get to race. But here is my problem, the final races are tomorrow, I only have these 4 props here, now, a M447 , X645, M645, and a X450. Am I correct to assume, that out of these 4 props, the M447 is the most conservative, and subsequently, safest, of the four?
                • ron1950
                  • 3024
                  i to use the m445 on t180 4074 2200kv motor no heat issues at all...i may try a m545 soon
                  • Chrisg81983
                    • Jul 2011
                    • 1556
                    I ran a 4082 last week with a t180 and a m645 and it pulled more amps than I was comfortable with for that esc just my opinion I found the 445 was a great prop letting the motor get some nice rpm's with speeds around 56 mph
                    • Bullwink
                      • Oct 2011
                      • 244
                      Good to know, but I don't have a 445. I will try the M447. I will have time in the morning to test it and check temps before the race
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        Bullwink................cut your m447 down to 45mm................then rebalance. Didnt know they made an m447 btw, unless you detongued it.
                        • Bullwink
                          • Oct 2011
                          • 244
                          Good idea. I got the m447 from OSE Sharpened, Balanced and Detounged. http://www.offshoreelectrics.com/pro...rod=octsb-m447
                          • TINY
                            • Aug 2011
                            • 176
                            No, cut down the x450 to 448 and detounge, lighten sharpen and balance... I'tll fly...
                            • Chilli
                              • Jan 2008
                              • 3070
                              So how did it go today BW??
                              Mike Chirillo
