Speed 3 Blade Over 2. How to work out?
  • Drax21
    • Jul 2011
    • 1021
    So I have been using OSE's calculator to work out what speed I would be getting and usually its pretty accurate but I can only be used for 2 blade props.
    How can I work out the speed with a 3 blade? Mathematicians at the ready
    Thanks
    Everything that has a beginning, has an End
  • jevmax
    Legend
    • Aug 2007
    • 368
    Prop pitch is prop pitch, regardless of the number of blades
    • Drax21
      • Jul 2011
      • 1021
      But a 447/3 surely would increase speed over a 447/2, no?
      • photohoward1
        • 1611
        No. Pitch is like a gear. More blades means less slip though. Kind of like a fatter tire putting more rubber on the road. It may slow you down actually.
        • Drax21
          • Jul 2011
          • 1021
          Thanks this is useful info
          • jevmax
            Legend
            • Aug 2007
            • 368
            I agree with Howard. In addition, a multi-blade prop presents a larger surface area in the water and creates more drag. In most cases, a two bladed prop will be faster.
            • Chilli
              • Jan 2008
              • 3070
              And put more load on the motor/ESC.
              Mike Chirillo
              www.capitolrcmodelboats.com
              • Goonboy2
                What me worry?
                • Aug 2011
                • 33
                Granted - a three blade prop should be slower than it's two blade equivalent and put more load on the motor & ESC but it should improve handling since there will be blade in the water at all times.
                Hammer rescue boat on 2S, Supervee on 4S, Rico 31 under construction on 6S
                HO train on DC power, Nirvana II on wind power, antique phonographs on wind-up power
                • jevmax
                  Legend
                  • Aug 2007
                  • 368
                  Yes. A three blade prop can have a stabilizing effect. It seems to be most noticeable with a mono.
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    ive always found 3 blade to be faster, and 2 blade quicker outta the hole. contrary to others findings. i will agree that 3 blade have less torque roll on a mono or v
                    • iamandrew
                      • 577
                      well 2 blade you have less mass to spin, less heat compared to 3 blade, but 3 blades just seem so smooth in the water compared with 2 blade
                      • lohring
                        • Jun 2011
                        • 183
                        The three blade will load the motor more increasing the current draw. If the three blade has the same blade shape, diameter, and pitch as the two blade the power required will increase by 150%. With lipos the voltage won't drop much so the rpm and speed will only decrease a little. This can be compensated for by running the three blade shallower, decreasing the load.
                        Lohring Miller
                        • Drax21
                          • Jul 2011
                          • 1021
                          Thanks, great info
                          • Chrisg81983
                            • Jul 2011
                            • 1556
                            I was told by someone that a 450/3 would be about the same load on the motor as a 455/2 so I tried it out and my eagle tree data was almost identical for the two props although it had a 2 mph difference the 450 was a tad slower
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              I suppose there are many variables involved... Too many to give a definitive answer.
