1/12 (?) miss budweiser prop recomendation
  • 69zandar
    • Dec 2011
    • 14
    My dad has a 1/12th ( I think , @ 26"-28" long ) miss budweiser that came with a nitro motor and he is converting it to electric , He has a seaking 3060kv and a 3s lipo . He has just a plastic 35mm prop on it , not sure witch one , and it will not go. I have tried to search for props for him but I havent found much other than the miss lumar comes with a y535. Does anyone have any recommendations for him ? I have not done a hydro yet so I am no help. His prop shaft is 1/8th " . Thanks in advance
  • Make-a-Wake
    FE Rules!
    • 5554
    Your gonna need to go with a 3/16 I.D. prop to get any diameter, you can use a shim to slip over the 1/8" shaft. If you work that out try an x440................x637............
    • JimClark
      • 5902
      Shimming the prop shaft is easy. Why 3s instead of the normal 4s used in that size boat?
      Billy Graham
      • 69zandar
        • Dec 2011
        • 14
        He has a couple 3s from a traxxas slash that he has had for a while . Would he be better off with a 4s with that motor ? Wouldn't that get the rpm's too high ? We are all kinda new to this . As far as shimming the prop shaft could a person just get some 1/32nd shim stock and roll a piece in the prop ? Thanks for the replies
        • Make-a-Wake
          FE Rules!
          • 5554
          He means 4s with a motor in the 1800-2200kv range. Your motor will work on 3s if thats what you have. You need a 120a ESC minimum.
          • 69zandar
            • Dec 2011
            • 14
            Yea he has a 120a seaking esc . Thanks !!
            • JimClark
              • 5902
              Sorry didn't look at the KV of the motor, As far as the shim goes you can shim the prop or here is what I do
              I use K&S tubing and will file the end by the drive dog flush with the drive dog and loctite together. You have to get a longer set screw and drill thru the shim tubing so you can get the set screw to hit the flat spot on the shaft.
              Billy Graham
              • 69zandar
                • Dec 2011
                • 14
                Nice idea Mr. Clark he is going to have to do something. Thanks !!
