recommendations of the propeller (46 'v-hull, leopard 5692)
  • kaistapaa
    • Aug 2011
    • 13
    Summer comes, and should begin to order and the propellers do not know what to order. under the title of the boat and the thought of the need to shave 8s and 9s.motor kv is 1090 and the drive units 3/16 "
    -kaitsu-
  • znus
    Broke, as usual
    • Jun 2011
    • 120
    I'm building a similar boat (5692 1320kv, 8s and 45" hull) and I'm gonna start with a 646/3, although I'm pretty sure these motors will turn a 52mm - 55mm without breaking a sweat. The thing that worries me in your setup is your 3/16" drivetrain. It might be a little weak for a 5692?
    25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
    • kaistapaa
      • Aug 2011
      • 13
      i hope that drivetrain can handle this motor.all hardware is from ose and i think quality is good,neverknow.i`m going to try props you say,diameter 52-55mm but what pitch?
      • Make-a-Wake
        FE Rules!
        • 5557
        x452/3 blade for 8s
        • Chrisg81983
          • Jul 2011
          • 1556
          I think a 46 mm prop will have a hard time getting a 45 in hull on plane as a 447 has a hard time moving my 41 correctly just my opinion I would go with make a wake suggestion but maybe try a 452 two blade first and a 455 two blade will pull about the same load as a smaller 3 blade like a 450/3 or a 452/3
          • kaistapaa
            • Aug 2011
            • 13
            More recommendations are heard .... selected as a Castle Creations hydra hv200 esc so it would be possible to increase the amounts of cell ..... (at the expense of the engine).
            I use 8s and 9s batteries and motor and esc's own cooling lines ..... I hope to work well for cooling.
            • Chrisg81983
              • Jul 2011
              • 1556
              Most of my setups have single water pickups on them and cooling is verr good I never have high temps
              • shawnboat
                • Feb 2012
                • 43
                What propeller do you guys recommend for the same motor, but 1/4" shaft?
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  The only thing i can think of is a cut down x467................cut down to about 50mm since the blade area will still be quite large. Either that or get a 1/4 to 3/16 reduction shaft.
                  http://www.offshoreelectrics.com/pro...?prod=oct-x467
                  • Old Sloppy
                    Harry from Atlanta
                    • Jul 2007
                    • 200
                    I had a .80 OPS powered Cat with x452/3 prop. if you accellerated normaly all was fine, if you jumped on it suddenly the 3/16
                    " flexcable would snap.
                    any smaller prop was just fine as far as the flexcable was concerned..
                    It really is a matter of prop bite ability (torque applied to the cable) rather than the motor size.
                    60" Expresscraft SuperCat
                    (2) 2028 Castle motors 64.7 mph
                    10s3p with x450/3 props
                    15,000 mah 40c cells,
                    • Mattwarner
                      • Aug 2011
                      • 487
                      What was the outcome of these thread? I am building a 46" mono with a 5692 on 12s (740kv) and have no idea where to start and had no replies to my separate thread! was thinking of a x457/3?
                      Going to use a 1/4 shaft stepped down to 3/16 for more prop selection
                      • Chrisg81983
                        • Jul 2011
                        • 1556
                        Matt email me at cgenovese83@gmail.com I have a ton of info 4u
                        • Mattwarner
                          • Aug 2011
                          • 487
                          Email sent thanks!!
