Prop options on a 33" DF
  • sigelitest
    • Jul 2011
    • 329
    I oopsed it is a 36 not a 33
    Looking for a prop size on a DF 36"
    Using a leo 5692 1340Kv
    5s single 5000ma 40c pack
    200a SF ESsc.
    I want to get some speed out of it and not melt the pack
    I have no personal experience with the 5692 motor, but if it performs as the specs say it should, start with an x450. That should get you into the mid/high 40s if the boat is trimmed well. You may be able to go up to an x648 but be careful....
    • sigelitest
      • Jul 2011
      • 329
      if i could get two packs in there what do u think on prop and speed
      • oscarel
        • Dec 2009
        • 2128
        Wow, that's a lot of motor for a 36" boat. I've got the Hobbyking version that I'm putting in a Stryker f41 and I was going to start with a X455. Have you purchased the motor yet? Have you seen the prices on these http://www.hobbyking.com/hobbyking/s...Product=18848?
        • iamandrew
          • 577
          Ive ordered one, waiting on one of the 1700KV ones
          ive got a few 40C 4s and 5S packs, so was going to use them in a 1M hull, hopefully it will work!
          • sigelitest
            • Jul 2011
            • 329
            I looked at the HK motor it looks nice. Already got this one Installed with home made motor mounts
            should i go 6s 1p or 5s 2p and what prop for that setup i want to get it above 60 with out blowing the pack
            fluid made me see that 1 5s pack aint gona cut it
            • Make-a-Wake
              FE Rules!
              • 5557
              On 5s that motor can spin alot of prop. An x455 or x452/3 should be right in the zone for you. As Fluid mentioned though, an x450 would be a good place to start safely.
