HELP! Need Excel Spreadsheet for Octura and Others
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    So I have some fancy calculators I'm looking to make available for all to use. At the moment, I only have it built for 40-50 props and have to do add each additional by hand. What I need is an Excel spreadsheet including prop #, diameter, pitch, total pitch, etc. Of course for the Octura props, I know the diameter and pitch, but it would help eliminate having to enter each by hand. Then I can map for most of the common motors and to each type of hull to calculate speed.
    Anyway, if you know where I can find the Excel Spreadsheet file for Octura or other props, it would be greatly appreciated and eliminate a lot of time.
  • Diegoboy
    • Mar 2007
    • 7244
    I'm not sure if this is what you want but I assembled THIS for you.
    Octura on the top part, ABC on the bottom
    • Meniscus
      • Jul 2008
      • 3225
      Danny, that's awesome! Did you end up pulling source html, then port over the tables? I'll work with this list and then add for other manufacturers. This has saved me a lot of time.
      • Diegoboy
        • Mar 2007
        • 7244
        I converted the PDF's to excel, (octura & abc) created a new blank spreadsheet, Copied, Pasted, and typed till my fingers hurt. Then voila!
        • Diegoboy
          • Mar 2007
          • 7244
          The reason for the spacing is to have a header at the top of every "printed" page (as opposed to flipping pages to see what the column represents)
