twin prop direction
  • video200
    • 837
    twin prop direction
    what is the prefeared way to run the props on a twin cat ?
    i se that some drive with the props turning outwards and some run with the props turning inwards what is the difference between the 1 ways?
  • carlcisneros
    • Jan 2010
    • 1218
    on any of my twins I have ever run, I run them turing at each other (inwards).
    That is just me.
    Am sure others will chime in.
    • jj2003
      HIGH VOLTAGE ADDICT!
      • May 2011
      • 1501
      In my test runs I have found that turning inwards gives you better top end speed and turning outwards gives you better turning ability. The long slender cats have a tendency to catch the outer sponse on a turn and flip if going to fast. If you flip the props outward and change the rotation of the motors outward, it will handle better on turns although you still have to let up on the throttle a little, just not as much.
      "If guns cause crime, all of mine are defective"
      45"Speedfreek
      , Fightercat #068 ​, MyYoutube Vids
      • video200
        • 837
        thank you JJ :)
        guess i wil be running outwards :) got a hold of a agiator S ( http://www.hydromarine.de/hm_22281.htm ) so it wil be fun to se how it behaves :)
        • TINY
          • Aug 2011
          • 176
          I've found the opposite, running a 37 cat inwards is much better in corning and outwards gives better topend.. my2cents
          Love to know the real truth.... Chime in now guru's... cheers
