what prop next?
  • the savy fluxer
    • Jan 2011
    • 83
    what prop next?
    hey guys i have a prop question for ya . i have a 32" pursuit with a 2000kv 4074 Tacon motor,180 amp turnigy ecs, 2 4500 mah 5s lipos in parellel and a x642 prop. im hitting 55 mph and i want to take it to the next level with a prop change.
    all my electronics are ice cold not even a little bit of heat. what i would be the next 2 sizes up in prop from the x642?
    thanks
    and yes i already know this is fast enough and i should not push my luck, but i have too. ya know.
    thanks
  • Make-a-Wake
    FE Rules!
    • 5557
    I cant believe you havent burned it up yet on 5s with a 642...........................
      Next up is probably an m545 or m645......
      • egneg
        • 4670
        I agree.
        IMPBA 20481S D-12
        • Drax21
          • Jul 2011
          • 1021
          thanks
          That set-up should take an M645 easily. I know diesel's does on a 2200kv Leopard on 4s so a 2000kv Tacon should be no problem on 5s. Just test it for a minute then bring it in, if all is well carry on. Don't forgot to post a vid!!
          Everything that has a beginning, has an End
          • Make-a-Wake
            FE Rules!
            • 5557
            Your electronics are cold cuz you live in BC, i'm not being negative, i just think you have maxxed it out, i hit 59 in my Pursuit with a 2150kv Leopard with an x442on 5s......................you're runnin an x642. Certainly try it if you must but i bet with a 645 its slower than the 55 you hit.
            • the savy fluxer
              • Jan 2011
              • 83
              thanks guys
