Holy Meat Cleavers Propman!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    I was sent these as samples from a manufacturer and WOW.
    The pair sizes range from 52 - 55mm and they are 1.8 pitch I believe.
    What kind of setup would these be good for? I can't imagine spinning up a pair of these on a Genesis size hull!
    Curious how to calculate these bad boys. Perhaps they might be for a larger, say 55" hull? Maybe for my 57" Arrow Shark Project?
    Anyone have some good working knowledge of the 3 blade props in this size range?
  • mm123521
    • Sep 2010
    • 150
    Ben,
    I am running a twin 6S, rigger.
    http://forums.offshoreelectrics.com/...-89.5MPH-Video
    I just bought (one hour ago) a pair of 50 MM X 1.7 (3.3 inch pitch), 2 blade, props from the prop shop in UK.
    At 38,000RPM loaded, these should give me a little under 100 MPH @ 15% slip.
    Right now, I am using X457's (3.14 inch pitch) cut down to 52MM and I am getting 93 MPH. (nothing is getting hot, so far).
    Hummm, a pair of those, 52MM x 1.8 (3.66 inch pitch) would give 110 MPH under the same conditions as above.
    That might be the next step for me?
    How much for a pair- one right hand and one left hand???
    Mark
    Avatar is the dangerous end of a Gatling Gun!
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      I suppose I could sell a pair, but really I'm curious how to calculate the application on these. That's a pretty sweet running rigger!
      • millzee
        Ozzie Bloke
        • Nov 2010
        • 1092
        How do you recon twin 1717's in a 42 sprint cat would spin them?
        "Gimmy Toyz for FUN"
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          I don't know, I'm not sure how to calculate the load on them. Just a guess though that they would move a ton of water.
          Anyone know how to calculate the load on these? There's a ton of props in FECalc, but none that I can see match up with the sizes of these.
          • ray schrauwen
            • 9475
            I would like a couple in left rotation.
            What Aluminum is it?? CMDI used 7075 and the R2 hobbies cnc props must be 6061 from what it looked like after 2 runs... Dings & little bends etc...
            Get them to use proper 7075 aircraft grade or they are disposable fairly fast.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              Nice Avatar!
              I'll ask. It feels like 6061, but I'll have to find out for sure. Thanks for bringing it up.
              FYI- this isn't a sale thread! lol... I'm really looking for a way to calculate amp draw and determine the best application for them.
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                Confirmed 7075
                • 6BOOST
                  • Sep 2011
                  • 286
                  Thats easy, put a pair of each in with my motors and I'll test them on my eagle tree for you I should have at least 3 twin engined setups, these would have been perfect for a twin 1717 mono, but I missed out on the mount on here a few days ago, I even had 4 of them to burn up for you too
                  6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
                  • carlcisneros
                    • Jan 2010
                    • 1218
                    Ben, those look like copies of the ABC props.
                    check their site www.abcprops.com and check out the prop chart section and locate the props with the same diameter.
                    a good place to start anyways.
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      Lol... they have a "cleaver" series there! Never looked at their props before.
                      I have quite a bit to learn about prop sizes and styles, that list made my eyes cross.
                      If I can make a match, I think the ABC props are listed in FE Calc. That would answer my initial question. =)
                      • carlcisneros
                        • Jan 2010
                        • 1218
                        Ben, only SOME of the ABC props ae in the FE calc. I am in the proccess of adding some more this week.
                        • Boaterguy
                          • 1760
                          Twinline T600's on either, send them for my DF 45
                          What do you mean by calculate load? i've never seen load numbers on props before.
                          • ray schrauwen
                            • 9475
                            Originally posted by FighterCat57
                            Confirmed 7075
                            sweet!
