Impulse 26 Upgrade Prop
  • MIGMaster
    • Jul 2008
    • 72
    Hi Guys,
    What would folks recommend as an upgrade prop for this boat ? I'm completely new to how the whole prop thing - I used to be a truck guy but I've played with boats a little bit over the last coupla years and I'm realy digging it now.
    Thanks !
  • sanyijr
    • 376
    Originally posted by MIGMaster
    Hi Guys,
    Thanks !
    MigMaster,
    So on the Proboat website, they suggest the Stilleto SS prop as a replacement. So I would go with either the Prather 215 http://www.offshoreelectrics.com/pro...i-prather-s215 or the Octura X640 http://www.offshoreelectrics.com/pro...?prod=oct-x640 should be good.
    I assume you are running the stock 550 motor and 7-cell NIMH....
    • MIGMaster
      • Jul 2008
      • 72
      Yeah - it's the stock configuration. Thanks for the insight - I'll give it a whirl !
      Thanks !
      • sanyijr
        • 376
        MIG,
        is the stock prop plastic? Or brushed metal? Cannot tell or find into. Only info I see is that the replacement is the stiletto.....
        • Darin Jordan
          • 8335
          I wish I could help you more on this, but other than initial testing and running the stock sample only a couple of times to test 6-cell vs 7-cell vs. Lipos, I haven't really played with a stock Impulse 26 much. I'm not sure how much prop the stock motor can handle. It's a 35A ESC with a 550-brushed motor... If I recall correctly, it can run through several battery packs before getting very warm, so I suspect that it can turn more prop.
          How many cells are you running??
          Darin E. Jordan - Renton, WA
          • MIGMaster
            • Jul 2008
            • 72
            Sanyijr:
            The prop is metal (SS I believe).
            Darin:
            I'm running nimh 7-cell packs (8.4v) at present.
