what is optimum prop speed?
  • Chenige
    • Jul 2011
    • 172
    What prop speed do you aim for? I see it can be calculated by KV x battery volts.
    With a:
    3000kV x 7.2 V = 21,600 RPM
    3000kV x 10.8 V=32,400 RPM
    Which is the better choice for a small mono? If you go with the "too high" 3S battery can you just dial down the ESC so it does not go so high?
  • BHChieftain
    Fast Electric Addict
    • 1969
    With a:
    I like to aim for high 20K or low 30K myself. Note, if you are talking Lipo, then it is 3.7V per cell, so your 3S would be 11.1V. I forgot who originally posted this chart but has come in handy:
    Chief
    • Chenige
      • Jul 2011
      • 172
      whoops. 33,300
      And thanks, per the chart 3S is the way to go.
      • Boaterguy
        • 1760
        yeah, 3S would be the way to go. if you were talking nickel cells, you could use 7S for 8.4V, and get a little more rpm, or try both. some people do run outside that chart, usually slower but I'm running a 1970kv motor on 5S, oops! hehe
