yeah, almost all metal propellers need to be balanced. Octura castings are pretty decent compared to a few other companies but expect maybe one hour of work per prop. As you said - sand of the heavy until both sides are of equal weight. Only remove material from the side facing the transom (this cannot bbe stressed enough!)!! I use a dremel for this kind of work and when it's balanced I wet sand with fine paper (around 500) until i get a god shine. It doesn't have to have a mirror finish but it should be shiny
A magnetic balancer is 30 bucks. Eventually you'll need it anyway because FE boating is really fun and propellers are pure voodoo magic. That little sucker is gonna turn 30000 rpm and a little wobble or off balance can shake almost anything loose. I know it the hard way.
what motor have you got in your boat?
