Tapping M4 threads in Octura x4 series
  • northernmike
    • Jun 2011
    • 17
    Has anyone done this? I'm about to attempt it. Any advice would be appreciated! I'll let you know how it goes..
  • martin
    • 2887
    The correct size hole for a 4mm x .70 thread is 3.3mm, Octura 1/8" bore prop is bored 3.2mm so the tap will be slightly tight when tapping so you need to take care when tapping using good quality high speed steel taps & thread cutting oil. The most difficult thing tapping a prop out is getting the tap running spot on true to the hole, Not always easy with a slightly under size hole either. Martin.
    • northernmike
      • Jun 2011
      • 17
      Thanks Martin! Maybe I can find a 3.3mm drill...
      • martin
        • 2887
        You have to be carefull drilling props as their not the easiest thing to hold so care must be taken & keep fingers well clear. Especially when drilling bronze as drills do bite in bronze. Martin.
        • northernmike
          • Jun 2011
          • 17
          Yes - I'm looking at my vise and thinking very hard about it now. Perhaps I'll need to make a fixture.
          • northernmike
            • Jun 2011
            • 17
            • martin
              • 2887
              Excellent, Screw it onto shaft or reverse it on the tap & rotate to see if its running true. Martin.
              • northernmike
                • Jun 2011
                • 17
                Runs true to my eye, but but better metrics will follow. Did not enlarge the hole - 3.14mm as supplied. On Graupner M4 stubs it is snug, but consistent.
                Supported in basic vise and tapped by hand - no mechanical alignment - 60 degree bites at a time, no lube. This is trial #1, of course - I expect to have to improve my methods. If I don't have to - I will call it fantastic luck.
                The entire process took about 20 minutes.
                • northernmike
                  • Jun 2011
                  • 17
                  Well, it's not very true.
                  Oh, well. Better next time.
                  • dasboata
                    • Dec 2010
                    • 3152
                    that could be from the tip on your tap
                    • northernmike
                      • Jun 2011
                      • 17
                      that was a haiku! ...
                      perhaps... but i doubt it. i may try it anyway.
