Octura "V" series props
  • jingalls007
    • 1015
    ..what's the deal? I've heard a very aggressive SAW prop that don't like turns. They take a bit longer to get on plain. Any other experiences or knowledge? practical application? thx
  • Ub Hauled
    • Aug 2007
    • 3031
    Yes to aggressive, yes to SAW prop, yes to not liking turns, the up to plain time will depend on size of prop, weight of hull, CG...
    lots of lift
    practical applications you ask? SAW baby!
    • jingalls007
      • 1015
      lots of lift
      lol! I don't run any SAW setups but these prop's sure do look cool...
      Thanks UB
      • Boaterguy
        • 1760
        Where can I get a SAW prop? what are the prices?
        • jingalls007
          • 1015
          I don't know much about these props, perhaps someone with experience with them can help you.
          http://www.offshoreelectrics.com/pro...eries+3+Blades
          • Meniscus
            Refuse the box exists!
            • Jul 2008
            • 3225
            The thing to keep in mind is that the lift in a V prop puts a much heavier load. For example, a V935/3 with an outside diameter of 35mm is over 5% faster and more load than an M445 with an outside diameter of 45mm!
            What I'm getting at here is that you can easily cook electronics if you don't appreciate the additional load you are putting on the electronics.
            In testing, we locally have discovered that we can cut a V935/3 down to 32mm for a 15" rigger. It turns well, but for that size prop on such a light model, it is the exception to the rule.
            • Boaterguy
              • 1760
              So, what you're saying is that they put much more load, but also much more speed, this means the SAW boats run HUGE esc's?
