Can props be sleeved??
  • Riversidedan50
    • Feb 2025
    • 32
    just orderd some props that had a 4mm shaft dia. and the prop drive I have now is 3.17 dia. .......... so am hoping they can be sleeved down to fit the 3.17 drive
    I needed 36 dia props and the only ones I can find were 4mm , so am learning the the3.17 props only go up to a certain dia prop then switches over the 4mm............
  • TLH101
    • May 2016
    • 61
    Yes, piece of brass tubing. Some props even come with reducing sleaves.
    • fweasel
      master of some
      • Jul 2016
      • 4291
      OSE sells different sizes of "prop adapters"
      Vac-U-Tug Jr (13mph)
      • NativePaul
        Greased Weasel
        • 2761
        while I know 4mm dog drive is a thing, 4mm threaded is much more common.
        If it is 4mm threaded I wouldn't sleeve it, the tapping frill size for m4 is 3.3mm, but you will be lucky if after tapping that is consistent enough to maintain prop balance.
        • Riversidedan50
          • Feb 2025
          • 32
          ok thanx however found out the existing shaft is too short for a 4mm prop so need a longer threaded shaft ......
