Would be a pretty neat build. I have never built from bare hull before so im scared to death about running the shaft through the hull and how to place everything. And for the price it seems its cheaper to just go with one of the minicatracing hydros, or even one of the ebay hydros. Just dunno which would come out most cost effective and perform the best. Might just keep my eyes open for a used bigger hydro with a sv setup in it. Thats plenty fast enough and fun for my sport running.
Who's Running a Micro? => Less than 16"
This is my shovel nose and it was my first build. Not quite a micro but all builds are basically the same.
IMPBA 20481S D-12Comment
The smaller size means you have to sharpen your driving skills!Attached FilesI let the dogs out...Comment
What setup are you running begwaveohs?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Completely stock:
LENGTH: 380mm
WIDTH: 200mm
WEIGHT: 372.5g without receiver and battery
MOTOR: 200mm x 40mm, 2 pole, 2600KV, 64g
ESC: Water cooled, 30a continuous, 40A (10 seconds)
BATTERY: 3S1P, 2100 mAh LiPo, 2A-6V BEC, programmable, 27g
SERVO: Mini high performance
DRIVE: Flex shaft, 4mm prop shaft, drive dog
PROPELLER: Plastic 30mm x 36mmI let the dogs out...Comment
Great info, what speeds are you seeing? And what props have you run?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Im really looking into the little minicat hydro. I like the fact I can run it in smaller pond areas that dont get hit with as much wind.
Is it possible to add a turn fin to both sides and maybe have it able to turn equally as well in both directions for sport running?
Im really trying to get my skunkworks cat finished so I can decide if I wanna sell the cat or the titan 29 that I have to just keep one for sport running then maybe build a larger hydro. God if only I was rich I would just keep and run every boat I want haha.Comment
I would like to have one of the Minicatracing Hydros to run while I wait for my Renegade Rigger to cool down between runs. Also like the fact that it is about the same size as my rigger!!
Anybody else having any luck running these?
Miniscus...Cool avitar! Are you going to be buying one also, or do you have one already?
-KentComment
Hey Rumdog, What size lipos did you run in it? Did anything ever overheat >ESC, Motor or lipos?Comment
I'm running a megatech h2o 9" hull with a 3000kv tiny outrunner a 30 amp mystery esc and a 1300 2c lipo. Octura 27mm prop cut down to 22mm, semi surface drive. No cooling and it gets warm not hot, runs for about 15min goes about 15mph and is self righting. It needs to be pretty calm water to run it but it is very fun.
MikeVComment
That is sweet!!! Can you post a picture?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
You'll have to borrow one from a neighbor and post for us to see
I like your description, it may help others with setup.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
