Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 17" mono motor, speed control and drive line - Offshore Electrics Forums
  • Propwash
    • Feb 2016
    • 12
    Any ideas where to get a 2835 and 2845 2900kv or 3100kv motors at. Spent the weekend trying to figure where to buy from a us supplyier. I have all the ships sitting off shore in cali. Going to buy s 50and 60 amp speed controlers just to make sure I have what I need. Waiting 5 weeks for parts to show up puts me in cold and possibly snowsoo[o. Need something shipped from the us.
    • NativePaul
      Greased Weasel
      • 2760
      If you are morally OK with clones, the HETRC EDF 3W is a good (for the price) American knock off of the Mega 16/15/3 that I use; 78g, 28x38mm, 3000Kv.
      OSE sell the Leopard 2845 2960Kv motor, similar quality to the HETRC, but at 28x45mm and 125g it is too big and heavy for a 17" boat unless you are planning on doing SAWs with it.
      Even for SAWs a 2860 is too big and heavy for a 17" boat.
      • eehess81
        • Jun 2021
        • 158
        https://www.offshoreelectrics.com/pr...l-F450B-KV3000
        This one sold on this website, not sure size but it's appropriate for 17". 3000kv, would work for 3s speed runs or 2s cruising.
        • eehess81
          • Jun 2021
          • 158
          I sent you a link to the motor I use from hobby king a few posts up.
          • Propwash
            • Feb 2016
            • 12
            Spam.. If this came on toast with a fried egg and cheese it may have been good oh dont forget the mayo..
            • Propwash
              • Feb 2016
              • 12
              Finally got everything to finish the boat. Just a few questions.
              On electrics of this size about where should my balance point be?
              How far from the bottom of the should the propshaft be?
              Do I need to offset the driveshaft to the right side (looking at the transom from the stern) and how far to offset?
              • eehess81
                • Jun 2021
                • 158
                CG should probably be about 5.5 inches forward from the back, about a third of the length. What do you mean by offsetting the driveshaft to the right? Shaft and prop should be in center of boat at bottom of V of hull maybe an eighth of an inch up from bottom. What motor and prop and battery you end up going with?
                • Propwash
                  • Feb 2016
                  • 12
                  The motor is a propdrive 2830 3000kv.
                  I used to have to offset the strut to the right on my nitro monos to counteract prop torque. Wasnt sure if that was needed on electric monos.
                  • eehess81
                    • Jun 2021
                    • 158
                    Never heard of offsetting prop shaft on a mono. My 17" with that motor definetely has a bit of prop torque with 3s. I have a counter weight far back in left which helps.
                    • eehess81
                      • Jun 2021
                      • 158
                      The 32mm prop I started with had way too much torque, I switched to a 28mm and it is much reduced.
                      • Propwash
                        • Feb 2016
                        • 12
                        I got an alloy prop for the barbwire as a starting place. Should atleast get it up on plane. I hope.
