So How Do You Mount a Rudder On a Foam Transom?
I gave this some thought and came up with this idea: A small block of wood, drilled and tapped for the rudder mounting screws gets glued into a square hole in the transom. The result? Rock-solid! The other prototype I'm building has a 1/32" styrene transom glued to the foam. On that one, I'll add an inset plywood doubler on the inside, then drill and tap the mounting holes. Thus far, I think this is the easiest method, but we shall see.
