The Evil Doctor's Next Project
  • Dr. Jet
    • Sep 2007
    • 1707
    #31
    Well this project took a back seat to the MPR and the Short Circuit for quite some time. With the Short Circuit nearing completion, this one will be coming back on the the bench.
    It's now the summer flying season , so building time will be greatly reduced, but I promise this one will be next in the water.
    • Dr. Jet
      • Sep 2007
      • 1707
      #32
      Well, here we are, almost a year to the day since my last post here. With the recent completion of the 16" Cat, this project will finally move up to the forefront. I did put a larger motor in the Atlas prototype and hope to have some vids of that the next time out. The scale Atlas will probably get finished painting in this time period as well and may get a motor swap if I like the performance of the new one in the prototype.
      • Dr. Jet
        • Sep 2007
        • 1707
        #33
        I epoxied the sponson pieces together using a gluing/alignment fixture I made. I drilled 5mm holes with the exact spacing of the booms in a sheet of 3/4" aluminum that was slightly larger than the outline of the sponson. Then I put 5mm pins in the holes and built a "Sponson Sandwich" over these alignment pins. I started with a sheet of wax paper, then the outer 1/64" ply skin, then the two 1/4" balsa sponson innards, then the other outer skin, then another sheet of wax paper, and finally a second sheet of 3/4" aluminum drilled to fit the 5mm alignment pins. This whole sandwich went into a bench vise and I pulled the alignment pins out before the epoxy started to set (I didn't want to risk gluing them to the sponsons). It would have been really easy to crush the sponson in the vice, so I only used enough pressure to guarantee that there were no voids in the gluing surfaces.
        Photos of the finished sponsons to follow when the epoxy cures.
        • Dr. Jet
          • Sep 2007
          • 1707
          #34
          The bare sponsons came out really light, about 8 grams each.
          • NativePaul
            Greased Weasel
            • 2763
            #35
            Wow, that is great! I didnt think that would be possible with wood, even with ride plates and sealant yet to add, I think they will end up being half the weight of my kevlar molded ones.
            Please carry on weighing everything as you go, I find it really interesting.
            • Dr. Jet
              • Sep 2007
              • 1707
              #36
              I used 1/4" contest-grade balsa for the "innards" of the sponsons which really kept the weight down. The insides of the sponsons are already coated with a light layer of epoxy, so not much more will be added with the exterior sealant. I will weigh the tub once it is completed and report the data here.
              • Dr. Jet
                • Sep 2007
                • 1707
                #37
                This rigger project has been on hold for a while due to some guitars I needed to work on, and now the Chinese Bat-Eating Flu scare has all the nitrile/latex gloves at Harbor Freight purchased by hoarders. Gotta have gloves if you're going to play with epoxy.
                In the interim, I have a new First-World dilemma: As I was digging through all my spare parts, I stumbled upon a perfectly good Neu 1112/1.5D. This motor is a BEAST in a 2950-class housing, and dripping with higher efficiency than most similar-sized motors. The motor's diminutive size means it's suitable for hulls in the 450mm ~ 500mm range.
                I'd like to find a suitable hull to build around this motor, but with a Kv of almost 5000 rpm/V, I'm somewhat limited. I could make a super lightweight gearbox and put it in a larger hull and try to take advantage of lighter weight over similar hulls with bigger power systems.
                Anybody have any suggestions what to do with this motor (no, I'm not going to sell it )?
                • NativePaul
                  Greased Weasel
                  • 2763
                  #38
                  That motor is enough to make a Mono1 or Hydro1 (lightweight, efficient 650mm ish, self righting) hull go well on 2s. Spirit of Ukraine or Falcon from Offshore Maniac, Exe2.5 from Ecomaster, Phoenix from RC-sails, Scord 3 or 5 from Tenshock, Arcas from ETTI.
                  It sounds like you are not after a build, so I wont suggest beefing up the other one of these you have, and putting it in there on 3s for a SAWs setup. (Sorry but with this Covid crisis I have lost my job, and am no longer in a financial position to buy the other one off you.)
                  • Dr. Jet
                    • Sep 2007
                    • 1707
                    #39
                    Hello NP,
                    Sorry to hear about your gig in all this Covid nonsense. I was hoping you would chime in on this subject; you always seem to have your finger on the pulse of what's new and cool in the European Mini-Market. You are correct; I'm not looking for a wood build, rather a complete composite hull. I doubt any of the 1/20 scale hydros I've done thus far would hold up to this motor, they're too lightly constructed and are more about looks than all-out speed.
                    While a dedicated SAW boat might be fun, it may not be the most practical application for my purposes. Besides, where would I find a prop small enough to run a 5000 rpm/V motor on 3S without letting all the smoke out? I'd like to put it in a sport scale hydro, but I don't see any appropriate hulls in the 500 mm range. Everything seems to be 450 mm or less, or 600 mm and greater. My second choice would be a cat, but again, it seems that all the hulls are either too big or just too small. The MHZ Micro Iceberg might work, but my prior experience with this hull is it doesn't corner very well when fitted with a lot of power. My next choice would be a mono, and here it seems like the selection of suitable hulls is much greater. My last choice would be a 'rigger. Yes, I would build one and the NeuMotor would make it a go like stink, no doubt.
                    Remember, I am not constrained by any rules for "class" racing. I don't have minimums or maximums to limit things, just my imagination, my budget, and my ultimate goals. In this case, my goal would be for something that goes around in circles really fast.
                    I'd like to follow-up on the suggestions you have made. Can you provide some links?
                    • NativePaul
                      Greased Weasel
                      • 2763
                      #40
                      X432 would be fine for sure and probably more, I've run a 4800kv 28x36 Mega 16/15/2 which is smaller and I don't rate quite as highly as an old Neu on detongued x435 and X632 for a fun 6 laps at a time, and a very cut up 32mm V935 for SAWs runs in a Mini Hydro with a castle 50A ESC.
                      I know you don't race, but as I am a racer 90+% of the FE boats I see are race boats, and 90+% of the non race boats I see are disappointing RTRs, so even though you don't need a race boat they will always be most of my suggestions.
                      Most of the cats I have seen in this size range I've made myself, if I wanted to buy one that would turn well it would be the Dr Psyko Flatcat, which I think is in the right size range, but I last saw one 5 years ago and I haven't seen many, so check before buying, and don't consider it if running in rough water is important to you, it is fast and good handling , but very much a calm water boat with low deadrise, tunnel depth, and freeboard.
                      Tenshock Scord 5
                      Etti Arcas rigger, they have squished the photo though as they often do with their thumnails so to see what it looks like you will have to to the Hydro1 section and view the sponsons and tub separately.
                      Ecomaster Exe 2.5
                      "Offshore maniac" in Ukraine make the Spirit of Ukraine, Stinger and Harpoon monos, Falcon and Hydron riggers in this size range, and "RC-Sails" in Romania make the Phoenix Rigger in this size range, they are proper cottage industrys, both make great boats, but neither have a website, I don't think you can link to a facebook page which is the best way to find them, but if you are on facebook look up those names, or if not, I can PM you an email address.
                      • Dr. Jet
                        • Sep 2007
                        • 1707
                        #41
                        Hmmm... FE Calc says that X432/motor/'rigger hull combo would draw somewhere in the neighborhood of 65 amps. Certainly doable, but run times would be limited. A tiny bit more pitch and a bit less diameter is even better in terms of current draw and projected speed. A Y531 looks pretty good, but they are only available in plastic. A de-tongued and slightly reduced X432 may be the ticket. Maybe even an X434 reduced to 30~31mm??
                        Anyhow, your response was exactly what I needed/hoped to learn and I will certainly follow-up on your suggestions.
                        • NativePaul
                          Greased Weasel
                          • 2763
                          #42
                          I have not used FE calc, can you link to it for me please? Do you input the boat size and weight? My guess is that it isn't scaling to mini sized boats properly.
                          In case there was any confusion I was only suggesting 3s for a mini size boat, with limited runtime. For all the boats I linked, I would use 2s without doubt, a 2s 5000mAh pack x435 (Hydro) or low area CNC 436 (mono) should net you somewhere around 5 minutes runtime.
                          I will embed a video of my mini hydro, a JAE Minisprint weighing aprox 560g running the setup mentiond above on a detongued X435, the average amp draw under power was 40A with a peaks in the low 70s, your KV is a little higher but your I would be surprised if it was more than much more than 50A average with the same prop. An x432 wont be pulling an average 65A in a mini rigger, that is for sure, my guesstimate would be about half that. I was pulling aprox 120 mAh per lap so could have run for 12 laps easily but not wanting to overheat my 2836 motor or uncooled ESC went for a USA race boat style 6 laps to limit run time and heat build up, I wouldn't recommend a 2200mAh battery and emptying it, but if you limit your runtime to about a minute it should be fine.
                          • Dr. Jet
                            • Sep 2007
                            • 1707
                            #43
                            The version of FE Calc I have is quite old and has its limitations, but when I input modern motor constants and propeller data it does a pretty fair job of predicting current draws. It is merely a simple spreadsheet program. It does not take into account things like reducing the load on a prop by removing tongues, back-cutting and other tricks, so if anything it tends to estimate high. It also has no idea what a twin motor cat is...
                            • Dr. Jet
                              • Sep 2007
                              • 1707
                              #44
                              While I'm on the topic of NeuMotors, I'd like to add that I have been friends with Steve Neu for nearly 50 years, and as such, I have an "inside track" when it comes to ordering and buying NeuMotors. Because of this, I have a few of the smaller NeuMotors languishing in my collection. At this very moment, I am in the painting/blueprinting phase of another Neu-powered Micro project that I have not revealed until now. What it is will remain secret, but as a teaser, I'll say this: I'm debating on the final paint scheme. I could do yet another "Short Circuit" theme, another "Auric Enterprises" theme, or the stock "semi-scale" theme, although I'm leaning towards the Auric theme as of today.
                              Stay tuned.....
                              • Dr. Jet
                                • Sep 2007
                                • 1707
                                #45
                                Some additional news on the NeuMotor front:
                                Another languishing project I have that is now seaworthy is my Vortex. This was one of the first Vortex hulls that had a turbine style hatch, but my hatch warped into something resembling a pretzel. I made a replacement hatch from a sheet of basswood and a streamlined bubble from a BBY micro hydro. The hull is stiff as a board now with CF floor reinforcement and expanding polyurethane foam against Depron stringers in the sponsons, nose, and aft non-trips to make all of those into one solid structure Power is a Neu 1107/2Y turning a cut-down CNC 1832/3 on a 2.25AH 2S.
