Venom rc boat with brushless motor park puddle
Tags: None
This run it did not because I placed 3s in the front of the boat, this was my 1st run I just placed the battery above the motor inside the cabin and it fits perfectly. Will go in a few again and test if it will self right. Boat is 60 grams lighter than stock and way way faster. I have two one has a brushed motor upgrade faster than stock buy a few miles I'll run them against each other to see how much faster this one is. I like this boat more than any boat I own because how cheap, reliable, strong and agile it is. I was surprised that after 30 minute run motor and esc got berally warm with out any water cooling.
Because I didn't want to waste any money upgrading this I used spare parts from a drone the 2300kv motor fits perfectly in to original motor mount if it gets pushed back a little, entire nose is empty space now perfect for a flotation foam.
PicturesLast edited by silencespr; 05-06-2017, 02:18 PM.Comment
i can't get it to self right wonder what i need to do... it does swim upside down from the prop pushing against the wind haha.Comment
Ok I was able to make it self righting again by pacing battery closer to the hull wall offsetting the balance. It's a bit nose heavy but under full throttle it stays well above water.
Attached FilesComment
Because the battery is up front the boat get off the line slow and fills up with water even if I have tape all around, need to find better solution to water proof it maybe the hatch tighter. When water fills up the boat no longer uprights.
Here is a video of a little race at the puddle brushed boat has upgraded brushed motor and is faster than stock.
Found some smaller sized lipos will see how well it does on them much more room now whole front is empty.Comment
I was able to fit everything back in original places think self righting should work perfectly now.
IMG_6762.jpgComment
Taking out these boats against my stock atomik barb wire lets see what happens in straight line.Comment
ran it against my stock barb wire and off the line it puts good 20 feet on barb, because barb takes a while to get out of the water, full out throttle its about 5mph slower but its is extremely stable.Comment
