Motor mount
  • speedsport
    • Mar 2010
    • 49
    Motor mount
    Any one know of any motor mounts out there for a 20mm dia motor? It's for a fairly small boat so I don't have a lot of room. It is a fiberglass hull though.
  • NativePaul
    Greased Weasel
    • 2760
    I don't know of any, if you have a drill and a drummer it is easy enough to use an aero mount as a template and make your own though, I do all mine that way. Normally much lighter than comercial mounts too as you make it to suit your boat and don't need it to be adjustable.
    I feel I should warn you away from 20mm motors though, while I haven't tried one in a boat myself I know several that have and the average quality of a 20mm motor is much lower than other sizes, and even those that bought high quality ones that on paper should have been very efficient at that power level have run very hot and slow compared to a short 28MM motor that doesn't weigh much more, and have ended up replacing them.
    • JimClark
      • 5907
      make your own
      Billy Graham
      • monojeff
        Moderator
        • Nov 2010
        • 2562
        Post a pic I could probably route you something fairly easily.
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • speedsport
          • Mar 2010
          • 49
          My only option is the 20mm motors. It's a very small boat
          • NativePaul
            Greased Weasel
            • 2760
            How small? What is the boat? You have me intrigued.
            20mm plus cooling can may not be much smaller than 28mm without cooling and may well run hotter.
