Miss geico 17 help please
  • ericrechlin
    • Apr 2016
    • 10
    I have a miss geico 17 I modified to brushless. I put a leopard 2550kv motor in it. It's very unstable at high speeds on my pond. Can I put turn fins and trim tabs to help stabilize it?
  • Mxkid261
    • Jun 2015
    • 734
    Front end bouncing? Or like rocking from side to side?
    • ericrechlin
      • Apr 2016
      • 10
      It has a lean on one side but most likely a leak in the flush mount water pick up. It wants to roll though when you punch the throttle.
      • ray schrauwen
        • 9475
        Counterweight. Can you shift the battery to the lifting sides bit?
        Nortavlag Bulc
        • ericrechlin
          • Apr 2016
          • 10
          The battery only fits one direction which is straight across the center
          • ray schrauwen
            • 9475
            I looked at the inside and it seems like the battery is held by Velcro and easy to shift a little one way or the other but I could be wrong if yours is different from the pictures.
            Nortavlag Bulc
            • ericrechlin
              • Apr 2016
              • 10
              That's the correct inside view. I'm running lipo 3s 1300 battery. It's longer than the factory battery
              • ray schrauwen
                • 9475
                Can you try to fit it in the left sponson? Center it lengthwise?
                other than that add a little weight t o left sponson.
                Nortavlag Bulc
