Atomic barbwire battery?
  • spectre
    • May 2014
    • 139
    Hi I just ordered this boat and wanted to order some spare battery's, but atomic says sold out. I'm not sure what type of connecter the battery uses. Does anyone know where I can get these battery's or a alternative that fits and has correct connector.
    Any other spares I should have, or anything you recommend for the boat. txs
  • nogeek43
    • Aug 2014
    • 16
    The Barbwire comes with EC3 connectors on the esc. I use 1800 mah Electrifly batteries from my LHS and they work fine. It will easily
    recover from a flip with the 1800 battery. You may need an adapter from Deans to EC3 for the Electrifly battery.
    Make sure you order a couple of spare flex shafts and props. You will lose a few.
    • spectre
      • May 2014
      • 139
      Thank you for the battery info, and I will order those spares too. txs 4 the reply
      • moneypit
        • Aug 2014
        • 7
        I had a mono x and the biggest you will fit are 2.2mah3s
        However the 1.8 mah that comes with the boat was quickest and fitted better
        • nogeek43
          • Aug 2014
          • 16
          I bought mine 2 months ago and it came with a 1300 mah. Ran well on that battery though.
