Well this will be my 2nd Jet sprint for the Boondal controlled class.
My first one is the same glass hull but is running a 2960 2200kv brushless set up as I burn't out 2 brushed motors for some reason. So it's not legal and while it's a fun class the brushless set up has way more torque.
This new hull is to the Boondal spec's but with water cooled brushes and a esc fan on the motor. Glass hull is from Damien from Boondal and you can buy it all in kit form from him and Ray. So lets have another shot at it.
Spec's are.
Hull .......................... Fiber glass
Hatch Cover................Fiber glass
Rudder with pick up.... Hobbyking TFL
Shaft.........................4mm flex
Stinger Strut.............. TFL with custom brackets
Prop..........................Graupner 2 blade 4056
Motor.........................Great Planes ElectricFly T-600 9.6V
Motor Mount................ Etti 540 mount kit
Water cooling kit.......... TFL
ESC........................... Blue brick Boat esc waterproof
Battery...................... 2200 3S Li Po
Servo......................... Standard Type
Driver Figure............... Tamiya Fox
V8 engine................... Chrome E Bay special
Spec's can vary a little but the Motor , Prop and battery are controlled for close racing.
Spec's are.
